I have been using SAE 30 as specified but wondering if I can used Honda 10W40. No sludge buildup inside as I have had it apart. The SAE 30 has served well, but is there something better?
Use anything with the Honda specified weight except new oils with friction modifiers. The clutch will not like low friction oils. Some people use JASO approved oil. I use oil designed for Diesel engines. Some people add zinc additives. There are a lot of opinions and very little science regarding these engines. The main thing is to keep it clean.
I just brought two quarts of the same Quaker state SAE 30. It has been working out ok. I tried Castrol 30 a few years back and it seemed thinner, and my clutch was slipping. I read that these old bikes should use non detergent oil.
I believe the idea behind that is that the detergents are supposed to be so good that they wash the gunk out of the centrifugal oil filter. I would speculate that filtration would be more dependent on particle mass than solubility in the detergent but can't say I know enough to provide you any guidance.
I chose rotella t4 10w40 for my cb160, added some zinc additive just in case
