Can't see them on the microfiche(s), and haven't found any in the bits that I stripped off the bike during teardown.
But I can't ignore that nagging feeling there should be some sort of rubber seals on the valve guides :shock:
Should there?
Thanks in advance.
Discussion Starter · #2 ·
Plot thickens.
CB350 K0-K4 gasket kits - which pretty much match the SL - contain valve seals. Again, nothing on any of the microfiche's.
Hmmmm . . .
For what its worth my 350 didn't have any when I took it apart but, like you, I had some in the gastket set so I fitted them.
There are no valve seals for the 350 engines.
I recently rebuilt the top end of my CB350: no valve seals were taken out and none were provided in the gasket kit.
Furthermore, the Honda FSM makes no mention of them, nor are they represented in the parts fiche.
So... I think you're good to go.
