1 - 2 of 2 Posts
Hi, I have a '68 450 and I upgraded to a later, larger oil pump. How much noise do your's make as you ride please? Thanks All! -David
Moved thread to correct section,
And the answer is none, pump should not make much if any noise. Its just a plunger not a gear or chain drive like on other engines.
If you can hear the pump you have an issue.
1 - 2 of 2 Posts
