Hey Folks, I am working on a '78 CB 400 T II and am currently stumped on the master cylinder restoration. The original piston was removed with all parts in tact except the boot which ripped coming out, of course. Lots of gunk build up which cleaned away well with brake cleaner and steel wool. The two openings in the well leading to the cylinder were cleared. Installed a new Honda master cylinder piston kit (part # 45530-404-315). Everything is moving when wet with brake fluid BUT very little fluid will come out at the threaded brake line connection point and none seems to be moving as if under pressure from the piston assembly. Fluid is not leaving the mc to fill the new line down to the caliper. Caliper bleed valve is open.
What am I missing? Any suggestions?
Thanks, Rob A
Thanks, Rob A
