Have adjusted the clutch a few times and still cant seem to get it to work. Will take off cover and try again. Did get carbs back from Brenneys in Iowa and starts and runs fine...Hdw
Probably need more info than this - is the ball bearing still inside the riser in the clutch cover? You've got the rod with scooped end facing the cover?
We also like pics of the bike!
Yes , took it all apart and new grease..will disassemble and try it once again..not sure I can start the bike and push rod just to see if disc are working properly...
Unusual introduction... basically, all we know is that you're someone in Bloomington who owns a CB360. Care to expound a little? And yes, pictures are a requirement around here... but welcome just the same :)
