I just tap then off using a flat blade screwdriver and a hammer, but be advised this can damage the grease seal and the thin spacer washer underneath..... If you are changing to tapers, not a problem....
Tapered bearings are not sealed.........Try "all Balls" or "tapered steering bearings' with the search feature here....
Discussion Starter #5
whats up sprint! so i looked in to the the steering stem bearings. i read that some people ran in to issiues of them not fitting or that the sets they bought came with no bushings.They also had issiues of them not sitting flush or not high enough ! Any brands you recommend or things i should look out for? Im just traying to do it right the first time if you know what i mean! ;)
