Hi,
Recently aquired a nice 360 T but it has a few niggling little faults one of which is the neutral light will not go off.
I have taken out the switch in the gearbox casing and it seems to move freely. However when I disconnect the wire the light still stays on. Is this correct or should it go out when disconnected?. I thought it would be a case of replacing the switch but now I'm not so sure. Has anyone else had the same problem ?
Cheers
Cheers
