Hello guys,
I’m new in this forum and I’m trying to find some correct info for these little bikes we like so much. Thanks in advance!
I’m struggling to set up properly the carbs. The mixture is rich as the plugs are soothy. She idles and runs good till the engine warms up, then lacks of power and even cuts down after a nice blast. Definitely the bowls are getting empty after the blast. The carbs has 98main jet and 38slow jet. Any of you guys know for sure the specs for the jets? I’ve found info online of people saying 90/38, 90/35, 98/35, 98/38. But I think the correct ones are 92/35 haha sounds crazy though. Anyway, I still have to play with the float and float valve but I’m sure there is more than one problem. All setup as follows:
Valve gap 0.05mm cold
Points: 0.35mm
Engine timming ok
Float level: 21mm from base
Petcock /carbs cleaned
Plugs: 0.65mm new
Compression: 8 bar( a bit low)
Well, we go from this guys!
Thanks Everyone
Points: 0.35mm
Engine timming ok
Plugs: 0.65mm new
Thanks Everyone
