Hello all quick question. On the bottom right side of my gas tank opposite side of the petcock is a gas outlet. What is this outlet for? This is a project bike and when I got it there was a cut off gas line attached so not sure what this is for or where to hook up the line. Thanks in advance for replies.
It's a crossover fuel line, there should be a matching connection on the back of the petcock.
The sides of the tank sit below the frame so the gas on the RHS would be trapped there without the crossover. You can buy an in-line valve so that you can disconnect the two sides as you will quickly find out what a PITA it is to take the tank off with that crossover.
