Good morning.. just need a bit of help with my cb360 carburettors .. im using some good second hand vacuum diaphragms but I think the little rubber locating tang is in the wrong position.. this means the air holes in the bottom of the slides are in the correct place (not facing the choke butterfly) what affect if any will this have on the bike performance.. Regards Roy
If you’re sure the slides are correct for your carbs and the tabs are in the wrong place, you could just snip the tab off, orient the diaphragm correctly and screw the cover on.
Slide holes should be nearest the filters/choke. If they are not, it won’t run right.
