1 - 10 of 10 Posts
Hey guys, new to riding in general. Made a probably bad decision and bought an 82 cm450a for cheap and it needs some work. I've finally got it running pretty good and it's idling fine but if I give it too much throttle it doesn't respond too well but this only happens when it's in gear. In neutral it responds just fine. If I work a bit slower it runs just fine and gets as fast as I need it. Just curious if you guys had any pointers on what I can do to improve the throttle response.
When you say it doesn’t respond well...does it stumble? Slow to come back to idle? More detail will help us help you :)
Is the air box and those boots in place? If not then that's likely the problem.
Does the accelerator pump work? You should see a squirt at the nozzle next to the choke plate when twisting the throttle fast.
My bad. It's just slow to speed up if I give it too much. Rpms will stay the same or even drop a little bit for like 2 seconds then it will pick up and get to speed just fine. It will come back down to idle just fine. No problems with going fast or staying at a constant speed.
Cables snap back just fine. Also, update. I ran it for a bit today and the issue went away after it heated up. Had to adjust my idle screw mid way through riding though. Spark plugs maybe? Love this thing but it's a real pos sometimes
OK, now that she's rideable add some Sea Foam or Berryman's B12 to the tank for 2-3 tanks of fuel. This helps clean jets and passages that may be slightly dirty. Follow the directions on the can exactly.
Sea foam done. Basically runs the same but smoother now. I have to tweek the idle screw after it's hot but, it's running like a champ. Checked my plugs and they look old so I ordered some new ones. Thanks for the help guys. ?
1 - 10 of 10 Posts
