So last weekend I yanked off my carbs to give them a cleaning, and I noticed backfiring pops in one of my pipes when idling. Carbs are cleaned and mounted on the bike, and the air leak has been fixed, eliminating the popping at idle. Now that I was satisfied, I decided to take the bike out for a testride.
Problem 1:
Before I put the bike in 1st I gave the throttle a bit of gas and instead of hearing the rumble, I heard a strange noise like the bike was underpowered. I look at the carb slides, and they were jiggling up and down when I would roll on the throttle.
Problem 2:
In the CB450 carb synch guide, it specifies that if you have no air leaks and you get maximum RPM with the air screws all the way in, then the carbs need cleaning. I cleaned out the carbs and I have the same situation. What should I do?
Problem 1:
Problem 2:
