Hello all, I'm new here and I am currently in the process of disassembling my carburetors for my '69 CL350 and it seems this plastic piece where the needle sits has been cracked for some time. Is there any way to replace this or will I have to buy new carbs?
Wood Circle Button Font Household hardware
Go to CMS or Partzilla and look up the part number. Go to your search engine and write down the make and year of the bike , the name of the part and the part number. If someone on the net has one it will show up. Make sure what they show is what you want . There are a lot same as and will work on your motor people that will screw you.
Bill H
Just put a little glue into the crack before it breaks any more. Their only job is to loosely hold the needle in place, and a repaired crack will have no effect on the carb operation. As far as I know, there are no replacements available, so if you do want to replace it, a used one is the only option.
