Hey guys,
I just installed some new exhaust tips and just from seeing/hearing it idle it seems to have a slight struggle here and there. Every so often it sounds like the engine is slowing down but then picks up again. Opening the throttle helps. I have not had the chance of riding it since I am doing some front end work. My concern is whether rejetting has to take place in order to work properly or if just playing around with the mixture screw and or idle screw will work? here are some photos. IMG_0941.jpg
It isn't unusual for some slight modification to the carb tuning to be necessary after an exhaust change. You have changed the airflow dynamics of the engine. Is it enough of a change to affect drivability? I would wait and see. Take it for a spin first.
Sent from my SM-G920V using Tapatalk
Unlikely any jet change will be needed, probably just resetting the mixtures. If you haven't increase the primary main jet 1 size already it might be needed.
