Hello, I need help on my 1964 CA95. I keep fouling plugs. I have a an after market foam style A/C. Can someone please take a picture of what screw to screw in or out. I have a stock carb I rebuilt. Do I need to change jets with the new or different A/C? If so I will buy a stock A/C and run that. Please help a brother out. Thanks in advance
James
The mixture screw adjusts the air/fuel mixture at idle, has little effect at higher throttle settings. It's located above the throttle speed adjustment screw, part #7 in this fiche:
https://www.cmsnl.com/honda-ca95-benlyusa-1320003_model993/partslist/E14.html#results
Adjust idle speed to spec, adjust air screw to achieve highest idle speed, repeat.
Changing air filters can cause rich or lean conditions but we need more information.
Does it start and idle OK?
How does it run?
Hi, thanks for the response..Yes it runs ok. It starts on the first kick or push of the starter. I wii try to set the air screw to the highest idle speed.
Thx. James
