will cleaning carbs in an ultrasonic cleaner with a simple green solution harm the felt washers on the butterfly shafts? do I need to take them apart and remove felt washer?
No it won't damage the felt washers. However Simple Green will cause discoloration of the aluminum if left too long. Pine Sol is an alternative.
I've been using LP Precision Clean in my ultra sonic and it works real good.
Both the Ultra Sonic Simple Green & Berryman's will dissolve the Oil on the Felt Washers and require them to be re-Oiled.
Both Solvents do an excellent job of stripping oil/Grease from the carbs and all related surfaces.
