On my recently acquired CB450 K1, I took off the carbs as it had been sitting for years and cleaning rebuilding them was one of the essential tasks I reckoned.
Getting everything off was easy enough; they looked like this:
The insides looked not bad having sat for 15 years:
Auto part Carburetor Automotive engine part
Obviously I'll need to repair the air filter and I have seen a thread here dealing with that. But two questions:
1. Anyone know where I can get the two rubber "seals" around the air box joins? The two in the centre of the first pic are dry, cracked and crumbling.
2. How did the bike run with the hole in the choke leaf? There is a part missing Will I be able to replace this with the relevant part from an old carb? Or will I have to find a complete replacement?
Thanks
eBay: 17213-292-000 air box joints $US 22 item #112543545043
eBay: 17311-292-014 air filters. $US 60 item #302134043676
You'll also need a gasket/o ring set for your carbs; clean the jets ultrasonically and reuse if possible rather than replacing.
Honda part #16010-346-305 these kits also have the instructions for use contained in them.
Good luck and welcome to the forum!
Nigel.
