Two questions, is there anybody out there who also has a 1982 cm250tb that I can get advice from?
Second, Tire Bicycle part Auto part Automotive tire Rim
Can someone send me a picture of this part of the cm250tb except assembled. I'm having a mental block!
Ps I hope the pic appears when I post this!:mrgreen:
After editing a photo on a computer most of the time you have to save it again or it reverts back to the original.
Looks like the question has to do with the brake pedal assembly
That's right. I took photos before the strip down, except not the right photos. The difficulty with the microfiche is that it shows the part assemblies, but not how the assemblies join together. Started this project years ago, through various issues, I'm hoping to finish it sooner rather than later. If there were someone out there, most probably Europe, who has the same bike I could get help if I need it.
I don't have the FSM for this model and CMSNL isn't showing the model. Being a CM variant though would mean it's probably similar to the US version. Here's a Fiche of the CM400T pedal ass'y. The brake pedal is screwed into the center stand pivot sleeve by bolt #29 which goes thru that plate #17, #28 fixes the plate to the frame. #16 is the sleeve the brake pedal rotates on and is inside the pedal. https://www.partsfish.com/oemparts/...747b87e3/pedals-change-brake-kick-starter-arm
Here's some pictures that might help
Auto part Vehicle Suspension part Vehicle brake Engine
Auto part Vehicle Tire Pipe Automotive wheel system
Pipe Auto part Wire Fuel line
Auto part Rust Vehicle Suspension part Suspension
Motor vehicle Vehicle Auto part Automotive tire Automotive exterior
The pictures hit the spot, made everything clear. The problem now clear was that this idiot sent the brake pedal for Chroming and this idiot didn't take out the sleeve. As a result, do I now press it out? The polisher seems to have curved surfaces. The brake lever goes tight, so will have to press it out and get it rotating. I can make a new one, if it's shortened, but what kind of steel are these made from is the next question?
Just checked an CM400 pedal bushing. It's mild steel, magnetic and scores easily with a file. It's got a reduction, @2mm, in the center area to hold grease and the ends, actual bushing surface, are @13mm wide. I'd take and post a picture but that function is inop until they get it fixed.
Made a metal cup, 25mm dia with 16mm inside dia and 12mm deep, then pressed the bush from the brake pedal out into this little cup, pressed both ways, in and out. Popped out, cleaned up no bother, greased, went back in a treat and works great, thanks for the pictures.
