My CL350 basket case came with a fastener kit, but no documentation. Does anyone recognize this kit, or is there a general standard for naming the groups? A, F, and G are right side out because they only had a couple each and you can see the complete contents under the label. B has acorn nuts, so I assume that's the group for tightening down the top end assembly, but there's at least one extra bolt in that bag that I can't account for.
315131
1971 SL350 K1
Stainless aftermarket. You'll just need to check and see where they fit best as you put things together.
After some more digging, I'm pretty sure it's either a stainless cycle kit or a copy of it. The eBay listing had a generic picture, but here are the contents broken down by group:
kit includes:
a:
points and tach cover
3 oval phillips screws
b:cylinder head cover
5 socket allen screws
8 acorn nuts
11 washers
c:intake and cylinder head
8 socket allen screws
4 washers
d:left side cover
10 socket allen screws
3 oval phillips
9 washers
e:right side cover
f:cam chain adjuster
4 socket allen screws
g:starter
2 socket allen screws
80 pieces total
I think I can sort it out from there, I just really didn't want to sit there sifting through a big pile of screws and comparing every time I was trying to put something back together. There was plenty of room to write the group name on the bag labels (I know because I did it :D), I don't know why they didn't just do that.
1972 CB350K4
All of the lengths are in the parts fiche, or most of them. You could use a caliper and match them to location by length / head type.
