hi i am replacing the camchain on a 1968 uk spec 175 sloper new chain is 82 teeth old chain is same when i pull chain to put on cam sprocket i cannot get ends the ends close enough to fit split link it appears chain is slightly short its on bottom sprocket routed properly i do not want to force it any suggestions please:
Did you reset the tensioner (compress the spring and lock it thus) so it does not yet affect the chain?
