1 - 2 of 2 Posts
I pulled the 350 out of the frame because upon reconstruction I timed it wrong and it won't turn through (piston meet valve, valve this is the piston). i timed it, got it to turn through, bolted it back up in the frame, down with the kicker, froze....check plug hole, valve meet piston, again.
What am I doing wrong?
I have the cam chain gear up level up top and the LT mark lined up. held it, installed tensioner and now.....help please....
Is it possible that you bent the valve, now it won't close ??? They bend in a heartbeat........
Look through the intake/exhaust ports and make sure the valves are actually closing all the way.
1 - 2 of 2 Posts
