I am building a new engine for my CB350K3. Specs will be roughly:
Will this setup work with a 123-X5 Megacycle cam or should I aim a bit lower? Maybe the 123-20 is a better match.
As a rider I am willing to cope with some negative effects but I would like it to be somewhat ridable and practical. It is not a daily driver but I'd like to take it on weekend trips to the mountains. To compare, I used to ride a XT500 with 600cc cylinder, lightened flywheel and crank with a pretty ambitious camshaft and for me that was fine on the road.
- 67.5mm pistons (from Todd Henning Racing)
- Compression: To be determined, can be modified but I start at 11:1
- Carbs: standard
- Air filters: I'd like to retain the original filters but large pods or foam uni filters are also on the table
- Exhaust: David Silver OEM replica's
- Head: NOS head with stainless Schumann Motorworks valves and beehive springs
- Ignition: Charlies place electronic ignition with standard mechanical advancer
- Eaton oil pump
- Cappellini paper filter
