2 teeth?
Did you not check during assembly or did something shift after you checked?
It's possible to fix in frame but I don't recommend it.
Roughly 23-ish degrees using the pic and a protractor, or ~1/16th turn, so in reality about ONE crank tooth or TWO cam teeth..... (Good guess Doode!....)
2 teeth?
I did check it during assembly. I think what happened is that the cam tensioner wasn’t tightened fully when I started it and it jumped.
