So I have a new to me 73 Cb450. Been taking it apart. Cam chain had a chain with a clipped master link in it. I always heard that was a big no no and it needed to be riveted. Is that true?
Second thing is the rubber/plastic gear wheel on the actual tensioner is shot. As in the one in the back with the big old spring and the adjuster. Think the little plastic nubs on the wheel broken off and in the oil pan. Appears the whole unit has to be replaced as an entire part? I also noticed Cappellini offers a ball bearing replacement with a shaft you have to peen on yourself. It looks a LOT more sturdy being a metal gear instead of a cheap plastic thing. And NOS tensioners are unobtainium. Grr.
I'm going to pull the tensioner off my parts 68 cb450. Hopefully it is in good shape. If not what is the recommended way to replace. The cappellini method or a used tensioner off ebay?
