How it Works
The cam chain rides on two guides. The one at the front of the motor is fixed, and rides on the chain. During engine running, the front of the chain is generally pulled tight because the crank is pulling down on the chain, and the cam itself provides load.
The cam chain tensioner blade(back of the engine) works by pressing on the back of the chain, where all the slack is, to keep it tight.
Ideally you want zero slack in the cam chain.
It's made of two parts.
One is a bowed peice of metal that's covered in plastic, that presses on the chain. Think of a flat spring, which is bowed out on one side. The bottom of it sits in a little cup, and to increase tension, the top of the tensioner is pulled down.
The second part is basically a spring-loaded slider. It's held in by a top bolt (to hold it stationary), and a nut on the bottom, which is released/tightened to allow adjustment. They're both accessable without removing anything from the bike. When the nut is released, the spring does its thing and tightens the chain by pulling down on the bowed peice.
This is applicable to the 450 series engines, the 400's tensioner blade is captive between the 2 case halves and can only be replaced by splitting the case. The 400 can be upgraded to the 450 and the 450 downgraded to the 400 by using the appropriate blade and lock plate
[attachment=0:1cybkq9k]14501-MC0-000_1-800x600.jpg[/attachment:1cybkq9k]
