Can I use one of those sealed AGM batteries like are used for battery back up lights, computers, etc. in my bike? It fits in the space and the voltage-6- and amps-10ah appears to be OK--.
My concern is are the connections robust enough? Seems like one push on the electric starter would fry them. I could hook it up without the starter wire if I need to while waiting for the proper battery to come---those are getting pricey and very hard to find anymore.
Before now my experience has been that the CA95 would kick start and run with a dead or no battery, but that does not seem the case on this bike. The key may have gotten left on a couple days ago and the battery is totally dead. No spark when kicking at all. Hope it didn't fry my coil. Just this Saturday I put in the newly charged proper battery (JA 3) and it started after sitting all winter on the 3rd kick and ran great. Today, nothing.....
Thank you for your help!
If you are discussing the batteries with the spade lug connections (emergency "EXIT" lighting, etc) I would concur it will RUN the bike but NOT the e-start ....
My concern would be Recharging Rate and I believe the bike would "cook" them
66 Sprint- yes, the battery with the spade connection. I hooked one that I have for another bike up(omitting e starter wire) and it started on first kick. I have used that battery on my Jawa 250 for years.
Do you happen to know, or know where to find, the generator output- I doubt if it is more than the 10 ma that the battery is. If I put a meter on the battery with it hooked up and the bike running can I check it that way? What would be a good number (it is 6 volt)?
Thank you!
Jack
The CB-100 singles put out 6V 50W @ 5K rpm...(to recharge a 6V 6Ah battery), so I'd expect it to be higher than that for the CA 95 with its 6V 10Ah battery.....
I'll wager you can get ~8.8V AC out of the pairs of alternator wires (unplugged from harness) @ 5K RPM or higher.......That's maybe 7.7 VDC peak @ the battery.......
90 Watts is the figure you get for generation using 6V and 15A (fuse) into Ohms law calculations....
