So now comes the CA. Given that it's essentially the same layout as the CL, I'm expecting the number of questions I have to be considerably fewer than I've raised in my other post, but I'm bound to come across things I can't quite get my head round . . .
. . . and I've already found one. It's to do with the factory cam lobe grind. Having disassembled the camshaft to extract it from the head, I've compared the left camshaft with the right and they look remarkably similar. Given it's a 360deg crank, that's not entirely surprising, but there's a couple of things about it that make me go huh . . . wha . . .? This is almost certainly due to a lack of familiarity on my part, but I thought I'd see if anyone could shed any light on the how and the why these things were made the way they were and how they function.
Since the engine is a 360, I'd expect the left and right sides of the camshaft to be mirror images of each other, with the lobes being the same profile/shape, and that they would exactly line up with each other when the assembly is together. What I've found is that rather than mirror image, the ends look to be almost identical if viewed from the splined ends. Maybe this will help explain what I mean:
The image on the left is the LHS camshaft; the image on the right is the RHS.
If you look closely at the lobes, they seem to have been ground the same way, with the flat on the top and the curve being sharper at the end of the flat than it is on the underside (I realise I'm explaining this badly . . . ). Where this gets strange is when the camshaft is fully assembled, because one of these shafts has to be rotated, which has the effect of orienting one set of lobes upside down relative to the other. I don't quite know how that works. On top of that, the lobes have an offset when the camshaft is assembled. So rather than firing exactly opposite eachother, there appears to be a small amount of delay or advance built in to one side.
So I guess my question is why are those things the way they are? The only reason I can think of for the former is reducing manufacturing cost, and if that's the case, the reason for the second is probably to make balance the engine performance/response given the oddly shaped camshaft.
Strange.
The cam lobes aren't symmetrical, maybe that's what you're seeing.
Nah, I kinda realise that. I've taken some photos but they don't really demonstrate what I'm getting at, so I'll leave that for now.
Moving on . . . how to interpret the FSM 'repairing limit' figures. According to the FSM, the standard piston ring gap is 0.15-0.35mm, with a repairing limit listed as 0.6mm more. Is it safe to assume that means the actual limit is 0.75-0.95mm?
I've measured the piston rings and the top ones are at around 0.6mm, with the seconds at a much tighter 0.4mm. This bike is likely to do less than 1,000 miles a year, so I don't need it to be as-new. If my assumption is correct, I'll probably go with them as is.
Cheers.
You must be measuring a set of used rings? Assuming the bore still in good shape, 0.6mm would seem to indicate a fair amount of wear(and a resulting loss of tension). Of course since we don't know what the gap was when the engine was originally assembled, the current end gap measurement doesn't really tell much. Personally, I won't willingly re-use a set of rings unless there are no new ones available. End gap measurements really don't tell much how much tension is in that ring, which is a measure how well it seals against the cylinder wall. Put a new piston ring in a freshly honed cylinder and material is worn off in the process of seating that ring(which is a normal occurrence), now take a used ring that measures"in spec" and introduce it to a re-honed cylinder(as some folks here are wont to do do) then material is worn a second time in an effort to get it to seat. That loss of cross sectional area in the further reduces its tension and ability to seal. I expect I'll be taken to task by some resident experts here for expressing My opinions, oh well, so be it.
Later: just dug My FSM, the way I would interpret it, the total ring gap limit is .6mm. DSCF0594.JPG
Discussion Starter #5
Ah - thanks very much, and boy am I glad I asked. My FSM must be a different year to yours (1971). It contains pretty much the exact same table, but as I said, the wording is ambiguous because it's missing the crucial word 'than'. That puts a totally different perspective on the sizing.
Annoyingly I'm having to take a hiatus until either the cotter valve that launched itself across the garage turns up or the replacement comes in from Holland (yeah . . . I know). Since that's going to take a few days, I'll see about a new set of rings in the meantime.
Discussion Starter #6
New rings are in. Engine is pretty much all back together and waiting to go into the frame . . . and I know the questions that follow aren't engine specific (or engine at all for that matter) but I thought I keep the board tidy and just add them here for now. Hope no-one minds too much.
Rear brake pedal spring - looking at the shape of it, I'm guessing ('cos I can't remember) that one end hooks around the centre stand tube on the frame, rather than the similarly-placed-but-about-half-an-inch-higher-and-much-narrower centre stand spring pin (the one the C-shaped plate clips onto). Is that assumption correct? The reason I'm asking is that when hooked behind the centre stand tube, the spring causes the pedal to sit at an angle where the rear brake switch spring basically rides against the swingarm, and that doesn't strike me as being right.
Starter solenoid/relay connections - fairly obviously, the starter motor connects to one of the posts on the solenoid/relay under the RHS cover, but I can't find another connector with a ring that fits on the other post. My loom has one ring connector on it, and it's right next to the fuse holder; from looking at the fiche diagrams, that looks to me like it should connect to the battery. On my other bikes, the solenoid/relay connection is a fairly heavy-duty cable because it's directly connected to the battery, but I can't see anything like that on the fiche. So what connects the starter solenoid/relay to the power?
Ground strap under LHS cover - I've got the L-shaped plate with the woven piece of cable on it but for the life of me I can't work out how it mounts to the battery. Admittedly I've got a newer battery than the one that would have come with the bike, but even so, I'm really struggling to understand how that cable/plate would have mounted to anything given its strange shape. Can anyone shed any light on that please?
RHS cover - the LHS cover has a couple of rubber pieces in it that hold its face away from the frame when closed (i.e. something to stop metal-on-metal action) but the RHS cover doesn't have any mounting points for that sort of thing. Instead, it looks to me as though there's a narrow channel that something - maybe a rubber lace or strip - should sit in, but there's nothing mentioned on the fiche. Am I missing something there?
I'll have a few more questions soon - again, the engine's pretty much ready to go back in, so I'm sure there'll be a few that relate to that.
Meantime, thanks for your help (and patience).
Solenoid bolt terminal #1 gets power from the battery positive through a 6 or 8 Gauge (heavy) wire.... The other bolt terminal goes to the starter motor with a longer heavy gauge wire.....
The light gauge Black/red wire is powered when the key switch is on, and grounding the yellow/red wire by pushing the start button completes the solenoids magnetic coil circuit.....
See in Blue.....
Discussion Starter #8
Ahhh . . . thanks for that. And all of a sudden, it's jumped out of the fiche image at me. It's one of those items that's not where you expect it to be, but once you realise where it is, it's kinda obvious.
Now all I gotta do is find the cable in my boxes of bits . . .
The original battery had extensions for terminals, so you need to make an "L" shaped adapter to use a modern battery. c77 battery.jpg
