Hey folks,
I had my bike on the road but one day, and the cone in the spark plug boot slipped out without my knowledge and the bike started missing, so I pulled over, and due to where I was, I had to go just bit farther to pull over. I pulled over. Noticed it gone and later went to go get new boots. Ignition was kicking in and out of full power and then just died. I open up to the points to start investigating, and the timing is out of whack. I investigate further, the cam shaft's end is busted. Now, obviously I must get a new one, but please help me and let me know EVERYTHING I need to check/know for this project, being that I am a new guy to all this, and I consider all my new found knowledge on bikes sacred. Thank you so much,
Matthew
Discussion Starter · #2 ·
Also, could I have done that when I was tightening the center bolt earlier? ALthough that doesnt seem possible...
Matthew....We'll need a picture to determine if you broke it, or it just broke, and maybe why....
you got it sir. Ill try and get one up soon. It was outside the head, it broke right behind the points.
I can't imagine forged steel "breaking" from tightening the bolt.... The bolt yes, the camshaft no, (or not usually)... was the shaft dropped that you know of?....This is a first for me.... :?
Yeah, I couldnt believe it either. It might have been dropped, but I have no clue. I don't believe it is broken on the inside of the engine , because when I turn the stator it still rotates smoothly, but then again, I am not an expert by any means. Ill put up some pictures soon and see what you think.
