Nighthawk 450, moved engine around to paint it and found this? Where might this go? It’s black in color. Thx
Certainly not to nit-pick, just to clarify - but the part descriptions from Honda's fiches have generally been in alphabetical order by "proper" noun form for the most part, with the terms separated by a comma. It's actually called "insulator, cable" which puts the description of what it's insulating after the part itself (the noun), like the base gasket listed as "gasket, cylinder" or the half-rings that hold the transmission bearings in place in the upper case of a 350 and 450 twin - "ring, set" which, of course, is a set ring... just FYI...it’s called an insulator cable.
