I need help! One of the bolts that retains the clutch springs just broke. Does anyone have a tip on how to get it out? The bolt broke from the head so a majority of the threaded piece is stuck. Please help
If you can get a dremel to it, then you can use a cutting wheel to cut a slot in the head (end), then turn it out. Or possibly use an impact driver to remove it, although that may bust it..
If not, a set of bolt extractors may help, if you can find one small enough to grip what's left of the bolt..
GB :)
With the bolt head broken off it should turn easily. I've turned one out little-by-little with a dental tool. But if it's not a clean break on the bolt head it could have a burr in the way.
