Preface:
Thanks to Jim, a generous member, and with a little added scrounging, I have most of the parts necessary to convert the front brakes from SLS drum to hydraulic disc on the 1963 Honda C 200 (90cc's) I am building for my 14 year old daughter .... While this particular example actually does NOT belong in a "twins" forum, the basic proceedures apply to a similar conversion on almost any bike, so I am including it here......Hopefully our new administrator will allow it to stay...... Steve
Project goal: To convert a small, single-leading-shoe drum brake to a disc brake set-up....
Here is a pic of the original set-up....
Immediate problems:
(1) This particular example has the Honda "bottom-link" suspension, and the fork width is very narrow (90mm) at its thinnest area.... Fortunately, the "links" project forward a bit and have a bit greater width at the axle clamps, so the "bare" spool hub has plenty of room on each side with the wheel centered on the stem.....
(2) The stock Honda rotor has an offset of 20mm..... With the wheel centered, I have only 13mm of clearance, so a "flatter" (less offset) and/or smaller (won't project into the constricted area as far) disc must be found and fitted...
(3) A smaller, less offset disc places the caliper closer to the hub where the spokes are at their widest, so a very small, thin caliper must be found and used..... This also means I'll have to fabricate a bike-specific carrier for the caliper....
(4) The generously donated wheel is actually from a CB200, and utilizes a 15mm axle while the original wheel used a 12mm axle, so this will entail several modifications to the "lower-links"....spacers, speedo drive, etc, not to mention I'll have to shorten a 15mm axle to fit the narrower width forks......
COOL!.... Now that I know what I have to do, I can proceed!.....
Step 1..... Assemble a pile of parts possibilities.... ALMOST done... I still lack a speedo drive gearbox/spacer, but can proceed with the rest.... "We dont need no stinkin badges!"...er....speedo drive (for now).....
Step 2... Find a rotor and fit it to the wheel.....
I intend to use a roughly 7" diameter rotor with a 10mm offset instead of the 10.25", 20mm offset CB200 stocker..... I found this rotor on one of those Chinese manufacture "scooter-mopeds" so popular now..... After machining out the center to fit the hub and drilling the mount-stud holes, here is a pictorial comparison....
The "new" rotor will be lightly surface honed before actual usage....
And here are some pics showing the (lack of) clearance I have to deal with....
I'll cover steps to correct problems 3 and 4 in my next post on this topic..... Steve
Immediate problems:
