Went to an auction last friday that had TONS and TONS of old motorcycle parts. They had so much that they were selling things by the box load. I wish Id had more $$ I woulda bought MUCH more.
This is a list by Honda part ## so youll have to know what # you need. I did try and figure out what they fit (BUT they may well fit many other models as well) so Ill post the Twin stuff that i know of first and go from there.
I suspect some of these are things folks wish they could still get for resto and no longer made, it is all NEW and still in the original Honda pkg. In some cases I have multiples of them so just ask.
GENUINE HONDA PARTS
18391-317-0CD
(repl 18392-MK4-000) GSKT,Muffler Exh. . CB360,CL450,CX500,CL77,etc.
93891-04012-07 SCREW, washer (4x12mm)
50619-425-010 STOPPER,strRubber
CM400,CB450,ETC.CB750F,K,L,
37243-323-000 COLLAR, inst.setting CB400, 450,350,650,750,900,etc
16997-273-006 GSKT., Petcock Many,CB,CL,XL,SL
22870-286-010 CABLE, Clutch CB350
(repl 22870-379-000)
44830-KB4-700 CABLE,Speedo CB400,450,500 ,CM400, CB750,900F CBX
44830-165-405 CABLE,Tach
MISC. Parts
90006-MA2-000 SCREW,Scr.Setting CBX
90104-430-000 BOLT, Frt. Cover Lower CB750F
43520-422-305 MASTER CYL Set CB (F's) and CBX
64109-MA2-000 Cap Scr. Screw
64513-MA2-000 PLATE,w/s CBX
90007-MA2-000 COLLAR,Scr.Set CBX,FL400
51490-MB9-782 FRT. Fork Seal Set
CBX,CB900,1100F,CX650,VF/VT 700 ETC.
33460-MN5-023 T/S Sub Assy Left Hand GL1500
08170-MN5-11 MARKER LIGHT, Saddle Bag E.I.
12391-425-016 GSKT, Valve Cover CB (DOHC F's)
(non Gen Honda part) VESRAH# VV-1002
77 Honda 750K owners manual (used)
Non Genuine Honda Parts
SHIM KIT, Valve- HOTCO (Hotcams) HCSHIM01
7.48mm Complete Valve Shim Kit (1.20 to 3.50mm)
(NEW w/Case. Check it out! NICE!!)
http://www.hotcamsinc.com/index.cfm?fus ... ductid=508
LIGHT KIT, Saddlebag Side Light (DS280821) Fits 88-95 GL1500
(NEW in Box, 2lights,will fit other models as well)
Ive also got LOTS of NEW chrome plated screws of various MM. From KKCycleParts. Just ASK and Ill look! :)
GENUINE YAMAHA Part#4ES-25448-00 SPROCKET, Rear CHROME
(NEW In Gen. Yamaha Pkg, Fits 93-01 YZ80 (48T-428)
GENUINE KAWASAKI K16030-014 RBLD KIT,Carb. KZ900-KZ1000
(NEW in Gen. Kawasaki sealed box) I only have 2 of these
USED PARTS
1980 CX500 ENGINE (partial,and partly disassembled))Good for Parts
1980 CX500 Rear wheel (Comstar)
1980 CX500 Driveshaft and rear drum
FREE - 1980 CX500 FRAME w/rear swing arm(no TITLE)
If you need anything let me know and make me an offer.
Thanks, Randy
If you still have parts, might you have?
cb400a carb (vb24a)
cb400a cables: 17910-447-000 throttle cable, 17920-449-010 throttle cable, 47500-417-000 right brake cable
cb400a parking brake handle 53180-417-000
cb400a solenoid/magnetic switch 35850-375-000
cb400a oil filter 154A1-413-505
cb400a oil pressure wiring harness 32180-417-000
cb400a oil pressure switch 37240-P13-013
cb400a air cleaner element 17211-413-000
cb350F cable, clutch 22870me7405
cb350f air cleaner element 17210333610
cb350F oil filter element 15412-300-024
cb350F solenoid/magnetic switch 35850371670
Thank you.
Jon
