OK I had my engine apart to fix oil leaks and ran into several bolts I could find no torque values listed for in the manual.
IN the interest of not destroying my engine from over tightening
Specifically the rocker box cover bolts both 6 and 8 mm and the rocker arm shafts with the aluminum washers on one side. And the breather bolts.
Torque Values
6mm 5.0 to 8.7 ft-lb
8mm 11.5 to 12.2Ft-lb
10mm 21.8 to 28.9 ft-lb
Well i figured out where my oil leak is coming from. those two rocker box bolts with washers over the points. Both are stripped from my over tightening. Is helicoiling an acceptable fix for these bolts?
