1 - 20 of 33 Posts
Replaced my stock tail light with a trailer light from a local trucker store. The bulb gets brighter relative to engine speed. After a quick jaunt around the block, the light is burnt out. I replaced it with the bulb out of the stock tail light (they take the same size), and it works again in the garage. I revved up the engine, and it gets much brighter with engine speed.
Does the stock tail light encorporate any type of circuitry like a zener diode that cuts out excess voltage? Any possible causes, or do you think it could be as simple as a bulb?
-MK
-MK
Nothing special about the bulb or the tail light in general.
Given a steady 12 volts, should work normally.
Sounds like you have a compromised battery or bad regulator or something else going on.......
The battery is good, it's new as of about 2 weeks ago. The thing that gets me is that the stock tail light works fine.
The "brightening" should be minimal ...The bulb should be able to handle the normal 12 to 13.7V output of the battery/charging system...... Sounds like the REGULATOR is not working properly... Check the connections, could be as simple as a "dirty" ground (green wire) connection....
I'll check on that regulator, it sounds like it's the culprit. I picked up a Ford regulator just in case this one bit the bullet...
Thanks guys.
-MK
Isn't the "Ford Regulator" mechanical rather than solid state?.....If so, it would be counterproductive to use it as they require too much amperage to operate.... Not a problem in a car, but the limited output of the bike is already marginal....
No it's a later model stolid state regulator. It's cheap, but pretty big and bulky...
I saw a write up somewhere on the net about a guy cutting one of those down/out of its case, to fit it to his bike. It looked good when finished..
Yeah I saw the same one, I think it was on DTT's $40 mod thread. I'm still trying to figure out the wiring, although I'm thinking trial and error will eventually yield the correct wiring...
IF you don't short out/burn up the rectifier trying it out..... :( :eek:
On the stock one....
Yellow "reads"and delivers the alt output..... Black is battery Hot (only with key on)taking the charge to the bike/battery... Green is ground... If yellow voltage exceeds 14.2V, the SCR "dumps" the excess out through the ground.....
So, As my "best guess".... I assume Yellow would be to the "field" terminal connection, Black to ignition-on B+ (battery terminal) and green to the ground..... How many wires does this "Ford" component have, and what are they labeled?... A pic might help....
You DO understand that a 750 has a very different charging system...Right?..... It uses an electromagnetically excited alternator that draws power to produce power, has a six diode rectifier, and originally used a mechanical regulator.... A solid state reg on that bike would be an improvement.....
Your system is way simpler...why complicate it?.... If your reg is bad someone here will have a good spare......almost every 12V Honda twin used the identical reg if it had one....160's, 175's, 350's, 360's,and 450's through the 500T.....
Yeah you're probably right Steve (as usual). I'll probably just pick up a used one and call it a day. I had this ford regulator laying around for a while and it only cost me something like $7. I thought it would be more reliable.
I replaced my regulator and rectifier with a solid stare typanium unit, cost $40 my rectifier was hosed, but I think I have a decent regulator, pm your address and I'll toss it in the post (its off a 72 cl 450)
Where did you get the typanium unit? Is there a web site?
I see you're from Marlborough. I used to take some flying lessons at the old airstrip there off of Rt20 and I also consulted to the old McDonald's that was closed just up the street.
Small world.
Discussion Starter · #18 ·
Steve, what did you mean by "SCR"??
-MK
SCR is a silicon controlled regulator.....Basically sort of a combination of diode and transistor that "Shunts" at a predetermined (trigger) voltage.... In this case, it shunts to ground, disappating the excess voltage...... NOT the best discription, but explanitory......
Discussion Starter · #20 ·
Gotcha, thanks! I gave my regulator a closer inspection, and one of the terminals has come off leaving the green wire hanging with nowhere to go.
Sounds like the root cause of my issue no?
-MK
1 - 20 of 33 Posts
