Is the Black Bomber axle shorter than later CB450s? Is the rear hub narrower? Is the swing arm narrower? Just tried to fit what I am pretty sure is a Black Bomber rear wheel to a Bomber frame with a later axle,brake backing plate and spacers. Axle is too long and the brake side spacer too wide. Just wanted to verify that this is the case so I know I have the correct rear wheel.
