I have a 1967 CB450 Black Bomber and it was missing the center stand when I purchased the bike. I’m now taking it apart for a restoration and found that the center stand is missing because the open loop brackets that are welded to the frame and hold the center stand are broken off. Someone welded two large washers in its place so that the brake pedal could still work. My question is does anyone know if someone is making a weld on replacement? I also have a parts bike to help with this restoration but the frame on the parts bike has the same problem, so I’m guessing maybe this was a common issue and someone is manufacturing a fix for it.
Thanks for any help you can offer.
