1 - 2 of 2 Posts
Hello,
I purchased a big bore cylinder and pistons(499cc) for my 68 CB450 K1... I also have the Athena gasket kit, my question is; Will I require a different gaskets if I when install this big bore cylinder/pistons? If so, what do I need and where can I find it?
Thanks
My first question would be... Does this cylinder fit in your cases?.... IF it does, you can use the standard size base gasket, if not, you will need a base gasket that "fits' the new (altered) sizing......
You will almost certainly need a larger head gasket that clears the larger pistons, preferably solid copper....Check the racer sites....
The rest of the gaskets SHOULD work.....
1 - 2 of 2 Posts
