I have finally found out the problem with my one carb, I think. I has to do with the circular plate that's connected to the throttle shaft in the carb.
On the left carb (the good carb) in idle position, only 1 of the two holes small offset holes are showing, and there seems to be no noticeable gaps around the disk.
On the right carb, (the bad carb), in its lowest position, both holes are showing, with the second one being partially shown. There is also a noticeable gap around the disk on the top right portion of it.
So after taking the disk out of the shaft, I can see that it kind of warped/bent (also, I did have it in the right way, with the beveled edges facing the correct ways).
So has anyone else have this problem before? Whats the safest way to bend it back to being straight, if possible? Also, the carbs are the 723b, and I found a throttle shaft assembly on ebay from a 723a carb. Would those be compatible being a and b?
