So i have checked and adjusted my valves and did the cam chain tensior adjustment according to the manual. but the engine is still a bit loud for what it is...is it possible that the balance chain tensior is the cause of hte noise? i would have done that as well until i realized that i would have to drain the oil in order to do so and i had just changed it, so im kinda prolonging it, unless of coarse it is the main source of annoynce, then its getting taken care of in a hurrry.
You may have enough adjustment. Take the round, chrome, 'inspection cover' out and loosen the 12mm hex nut. The spring tension should move the adjustment to the correct tension. If, after that there is still not enough adjustment, you will need to remove the clutch side cover. (if the oil is fairly new, you can drain just the oil and put it back in....another 'cheap' method)
