Broke timing chain?
No luck. So pulled a plug, literally no pressure coming out. Only can hear the turning of gears when hitting the kickstarter, or starter button. And clicking.Pull the spark plugs out and put your finger on the holes one side at a time to check for compression in each cylinder while slowly pushing down on the kick starter. Make sure the kill switch is turned off so you don't get shocked by the spark plug lead. If you get a blast of air from the holes then I think the cam chain has not broken.
Pull the valve covers and alternator cover and turn the crank with a wrench, see if the cams are movingNo luck. So pulled a plug, literally no pressure coming out. Only can hear the turning of gears when hitting the kickstarter, or starter button. And clicking.
You beat me to it Tom, LOLPull the valve covers and alternator cover and turn the crank with a wrench, see if the cams are moving
****, **** ****.. I literally was celebrating today because I'd finally get to do a test ride. This is my first bike, first build, first actual ride on the dang thing.Let me amend what I said about the need to pull the motor if the cam chain is broken. It MIGHT need to be pulled. I did repair my old 550-4 when the chain broke at 5000 miles on I-95 at 3:30 in the morning. I pushed that thing 3 miles and arrived home at 6:30. This incident was the basis for my User name on this forum.
It might be possible to fish the chain out of the crankcase and if the master link or broken link comes with it you might be able to connect a new chain to the old one and feed it through and around the cams and tensioner and restake a new master link completing the repair. It sounds like it might have broken, (if this is the case) while you were trying to start it and maybe caused no damage. If the link broke and fell into the crankcase then it might be pulled out with a magnet, but would be difficult.
I know this is not what you want to hear, but rest assured, many on this forum have experienced a failure which required a teardown and rebuild of their motors.
Thanks, I know I'll get through it, if anything, gives me an excuse to continue to tinker on it. So, I pulled the cam cover on the exhaust side, chain is still there, I haven't tried turning anything, just opened and can see that it's there, tried to budge it by hand to see if there'd be any response, but couldn't but also not sure if I should be able to turn it by hand.We have all been there. Do not allow this to discourage you. These old bikes can try our patience sometimes, but in the end it is worth the hassle.
When I purchased it did not run, however, compression was good, just needed coils, timing, and carb rebuild to get it going. Once I got it running, I did not ride, as tires were cracked. So I began on all of the other things, lights, controls, new wiring, bars, seat, paint, gaskets, crankcase covers, cables, etc. With everything else completed, and after buttoning up wiring, this is the first time I've tried starting it again, and then this. The clutch probably needs more adjustment, but could this cause these issues?I'm jumping in here with some quick questions.
Did you personally ever run it, or check compression before today?
What's your valve clearance at? I don't know the 70s 450, but are you able to confirm your cam timing is good and valves are within spec?
Non compression side? Not sure if I follow. With me trying to start it, can't this increase or bring probability of more damage?Remove your air filter and put your hand over the throat of the carb. Try and start it and see of you feel suction from the non compression side.
