Anyone using hotter b6 plugs? Any advantage, disadvantage? Or is this to hot and could cause damage? This is what i have been running because it is what the PO had in it. Now i see the manual recommends b8 and some are running 7's. So im concerned about using hotter 6's. Thanks
Hotter plugs usually help with an engine that is suffering from worn rings as they help burn off oil a bit better. Use the range the manual sets for your given engine there is no reason to use anything else on a healthy engine.
Sent from my SAMSUNG-SM-G891A using Tapatalk
