As the title states, are there any significant detrimental effects with running the CB360 OEM (or New OEM-style) air filters without the plastic air box cover? This would be for the early style air filters (larger ones).
Makes sense. I guess I will find out when I eventually get the bike started up after the rebuild. If I find myself chasing my tail on fiddling with the carburetors, I will try checking eBay for a set of air boxes.As with all Hondas since I've been involved, most times the airbox itself is ducted to create a certain level of resistance for a reason. The cover over the filters is only open in one area, so if you remove the covers it will allow the filter to have full access to airflow from all sides with less resistance. It might not make much difference in this case, but it certainly does on some models
Oh you know...here and there...Krukster -
Where have you been? Haven't seen you in a while.
What exhaust you running ?Well you guys convinced me. I found a set of pretty cheap on eBay. Just needs a fresh coat of paint. Better safe than sorry!
Original Honda CB360 Exhaust.What exhaust you running ?
Thanks! Ugh...I can't wait for the day that I get to start it up for the first time...and then unveil another mess of problemsWhat a beaut you have there!someday...
Got it, thanksThere are two bolts, one in the center of the metal housing and one in the top rear corner of it - the center one holds the housing on, and the corner one holds the filter. You’ll need to loosen the clamp seating the rubber mouth from the filter box to the carbs as well. If it’s been sitting for awhile, that one might take a little gentle working to get the rubber loose. From there, it’ll all come out as a unit.
There’s a slot somewhere along the open edge of the housing that you’ll be able to see once it’s out. A small tab on the filter metal fits into it, but I find it’s more a formality than providing any actual holding power.
