This chart is from the 450 Manaul, but the values listed generally apply to all bolts of that particular size.....ol55 said:Is there a torque spec for the rear axle? what about the torque link?
Thanks, Larry
ol55 said:Oops! -on a 350G model ( non diesel)
Thanks Bill2 -I was able to find it in the manual (thanks for the manual also!) after looking at your chart. Are those four Front Fork Axle nuts that tight -550 to 650 kg. cm. (about 43 foot lbs) The nuts seems smal to take that torque.
Larry
lolol55 said:Oops! -on a 350G model ( non diesel) Larry
Both my torque wrenches have in/lbs, ft/lbs on one side and newton-meters on the other.gord said:I wish my 350 manual that I have downloaded gave torque specs like that above, my table gives kg-cm, I don't even know if I can buy a torque wrench in kg-cm. I have a metric-imperial conversion website on favorites I go to, just an extra step though.
