21 - 22 of 22 Posts
As you move forward along the backbone, you should find the three wires for the flasher relay (Black, Gray, Green)...The relay should hang in a rubber loop (usually just behind the coil).....
There should also be a "branch" for the ignition switch (Red, Black, Brown, and Brown/white stripe (usually a single multi-plug), and nearby a Black/White stripe wire to the coil.....BLUE from the coil goes to the condenser (mounted atop the engine), and continues to the points again as Blue
A two wire branch goes to the horn ( Black, Mint Green)
Let me know when all these are correctly connected colour to colour....
You should NOW be close to the "spaghetti end" of the main harness......
We'll deal with one side's switching at a time.....
At this point, I need to know if there is a Blue with White stripe wire coming from both side's handlebar control units, or not.....
Discussion Starter #22
We have lift off Thank you for your help The head light end was all sorted so once I had connected the flasher unit as above and also put the head light lens back in it all worked . I didn't realise that by taking the lens out I had discontented the earth circuit for the front indicators as well Thank you for your help I am very grateful :D
21 - 22 of 22 Posts
