I am rebuilding the carb and I took out the air mixture screw and spring but the washer came out and o ring on the other the oring then washer how does it go thanks which is right
Discussion Starter #4
Also the only oring that I see on the bottom of carb is for the air mixture only. The needle valve gets just installed on clip to the float. The rebuild carb parts comes with some orings but I only see one inside the bowl area and one on side of the air valve is there any thing I am missing I see there is some between the 2 carbs Thanks for your help
Discussion Starter #6
My homework was done, unfortunately the previous owner disassembled the carbs before me. Parts were in a zip lock bag for me to assemble. With the help hopefully will all will be good. Thanks
Discussion Starter #7
So what I see is no. Only in the air mixture is the oring, inside the float bowl that is all. Thanks.
Discussion Starter #9
Thank you got that tutorial now that helps me I appreciate that Basically I am going to clean and change the gasket in the float bowl and the one oring in the air mixture. Also the air valve on the side has to be changed cause it is shot the rubber but I did see that oring. Again if you remember any other prints please let me know inside the float bowl. Again thanks for your help
