on going saga on my 71 cb175, on the right carb, if I squirt carb cleaner around where the throttle cable goes into the adjuster into the lid over the throttle valve it kills the engine if only that cylinder is running, any ideas on how to seal it, thought about using permatex black gasket maker. its the only place on both carbs that reacts to the carb cleaner.
