Hi everyone, thanks for taking the time to read this. I've finally found some time this later Winter - early Spring to dive back into my '72 CL350. I'm new to working on these motorcycles and am looking for a little guidance. I've just cleaned my carbs and checked the jets.
The PO had different jets in each carb body (#105 main jet in one side and #100 in the other). The bike came with original air boxes and new air filters, but the PO was running 6" UNI foam filters and said it drove well. How/why would he use different sized jets? Or was he just a bonehead?
Because the jets were different I figured that I'd just buy a rebuild kit from Common Motor and start from scratch. From what I have found out, please tell me if I am mistaken, is that the main jet primary for this particular carb is #68. The Common Motor kits comes with a #70. Will this still work?
I know the old timers and purists only use the air boxes/filters (and probably for good reason) - which is the plan - and say you can't get these motors running really well with pods. So how come so many owners use the pod/foam filters and how do they know what jets to use?
Thanks Fellas & look forward to reading some responses.
Cheers
Cheers
