Well its time for my next project - my little 65cc Benelli aka Faust. In disassembling the bike and cleaning a bit I could not tell if there was oil in the fork or not. On my Honda Trail CT70 it does not have oil in the forks just compression springs and I don't know if this one is the same. Is there an easy way to tell if there should be oil or not?
Attaching pictures for review.
Auto part
Auto part Ammunition Cylinder Hardware accessory
Auto part
Tire Bolt cutter Metal
They don't look like you can disassemble those forks Curtis imo.
I would imagine that you can possibly adapt a pair of oil forks from another bike w/ the same dimensions to your Benelli.
When I was about twelve my neighbor had a Benelli mini, prob same as yours. It was a cool little bike, faster than our z50. Two stroke.
Yep its a cool little bike. I think I'll go with no oil in the forks initially and then if the front end is too "springy" then I will drop in some 20wt oil.
Hi mate. I am rebuilding a benelli. Did you find any new dust seals?
Hey - Just resurfacing. No I have not been able to find any dust seals so I am using neoprene dust seals and running 4oz of 20wt oil. I was able to get them completely apart - have to twist ccw and they thread out with the spring and all. Looks like they run a little oil to keep things lubricated. Sent mine out for cerakote and will post the results.
