Ok, so I thought the hardest part would be to figure out exactly how to place the dust seals. One with a steel collar and one without on each side of the swing arm. Steel collar to the inside. If that is incorrect I hope someone corrects me.
Regardless of how the seals are installed though, you still have the same amount of room to work with. This fit is not snug, it's darn near 1/8" short of room :evil:
Do I need 4 hands to hold this assembly so I can sledge hammer it into place [email protected]#[email protected]
Do I need to remove it and sledge the frame tabs out a bit? I know I had to whack it good to get it out, but Aarrrggh! And yes, the frame is empty, there is no motor or nothing holding the lower frame tight together, just the rear fender and grab bar have been cinched into the empty frame.
