First pic:
I got two wires with factory looking connectors that split before the plug of the harness. The left hand controls. Orange with white strip and a light blue with white strip
Second pic :
I?m showing a solid brown wire coming out of the main harness side of the plug that goes to the ignition ....
What should these be plugged into? Or do they even need to be?
3rd pic:
I?m trying to stick all the wiring as much as possible under the tank since I switched out the headlight this morning and was trying to clean up the appearance a bit
Orange and Lt. Blue with the White tracer are for run lights, the solids Orange and Lt. Blue are turn signal
There is an extra Brown connector in the harness that was for a headllight park light required in some European countries
so i should be fine without them then it sounds like...im surprised they (honda) just didnt cap off these ones that werent needed here?
I believe the harness's were a universal design so 1 part fit multiple, same model bikes and the various countries
